everything is plugged in and turned on. worked two nights ago. was shutoff and has not been used...
(More)
everything is plugged in and turned on. worked two nights ago. was shutoff and has not been used during that time. lcd light is orange. if unplug says self-test. what else can i do
monitor is dark but when i hit the auto/set button it gets brighter for a few seconds then goes back...
(More)
monitor is dark but when i hit the auto/set button it gets brighter for a few seconds then goes back checked setting brightness is 100 percent
The monitor is probably on protection. To start unplug monitor
from power and from computer and test computer with different monitor
to find out if...
written by ginko
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the...
written by worthy42
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor...
written by BobbyR1234
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is...
written by dileep007
When having problems with any monitor the following are the first things you should check when troubleshooting: 1. Check to make sure the power source...
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air....
by wikihow
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction...
by wikihow
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors...
by wikihow
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
