I hope these help. Otherwise, please post a comment your server model and the light combination that you are seeing. I may be able to assist you with the error code.
When the motherboard boots up, it makes 'beep's to tell you information about the health/condition of various motherboard components. Usually a short single beep indicates "all is goog" but you hear anything else, like multiple short beeps, the manual generally interprets the beep pattern into plain language message as to what part failed. The failure of ANY part that is physically on the mortherboard, not plugged into a socket, usually mean
the motherboard has failed. It's possible, but not easy to replace mother board components. They are small, the soldering joints are small and if you don't know how to solder/unsolder on printed circuit boards generally you'll do more damage than was previously the case before you tried. Just identifying the specific part can be challenging, again, especially if you've not done this level of precision work.
The solution: get a new motherboard, and while you are at it, get a new CPU and memory sticks if you want to be on the safe side. Not all CPU's fit every motherboard, and memory sticks come in several configurations. Anytime I replaced a bad board, I got the whole package and asked the technician to assemble them and let mee see it boot up at least the point where it requests a proper boot media, such as a harddrive or bootable DVD/CD.
You can conveniently crack open the case without tools by swinging open the door that covers the front bezel, using your fingers to untwist a setscrew that lies underneath, then sliding off the side panel
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
in order to remove the keyboard
1. remove the hinge covers and then take the grey strip out where you have the power buttons also
then you will see the 2 screws for the keyboard .
Then take the keyboard out .
NTDETECT is the system boot file. Something has corrupted it. There is no way to boot the system if it can't read this file. If you have the windows disk, boot from that. The easiest thing to do if you have the disk is just to re-install windows. If you do an upgrade over top of itself, you will probably save your data. If you don't have a windows disk, get one.....
