SOURCE: Does anyone have a manual
This may be a warranty issue. You should find directions in the manual that came with the oven how to change the globe. And what the replacement should be used. In the back of the manual there will be a 1-800 number that you can call to see if the globe is a warranty covered item.
Hi, tell me if im wrong but are you going on about the light globe in the top of the oven, if you are then all you need to do is unscrew the glass part it may be greased up with grime but it will unscrew give the glass a good clean then try using a slightly damp towel to unscrew the glass part, it will unscrew then once you have got this off you will be able to get the bulb out, take the bulb to a hardware store and ask them if they can match you one up of the same type, then when you come to putting it all back together give the glass globe a good clean in hot soapy water before putting it back doing this will keep it from clogging up the next time should you need to change the bulb again.
if you are going on about something else then im sorry i got it wrong and tell me what you mean then ill do my best to assist you further.
let me know how you get on or if you need further assistance ok
