The tub is held in place by dampers (shock absorbers) and springs. When one of those breaks or comes loose, the tub cannot spin out the water correctly. It would help if we know the make and model.
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
grease may be trapped between inner drum and if taking apart steam/pressure clean between the drum and internal use full container of borax use very hot water and run an empty full load wash
I had that problem at one time with my old washer and what it ended up
being was the Washer Dog Agitators were broken and causing the it to
slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
Let me know if there is anything else I can do.
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
