these devices do not require drivers in windows or linux systems, if you are using a very old linux system please update to a up to date version like ubuntu www.ubuntu.com
Hi THERE,
This model is now discontinued. The replacement is DUP-DP-AS3-11B. *NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
Standalone, no PC required.
DDR2 Technology allows up to 8x Blu-ray duplication.
SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
can you see your dvd drive in bios ?
if yes, can you see your dvd drive in windows explorer ?
if you can't see it in windows explorer, it's windows issue,
either you can reload the operating system or you can edit windows registry.
if you want to edit, follow this step from microsoft (link below): http://support.microsoft.com/kb/314060
