Watches Logo
Posted on Nov 07, 2010
My salton innovations radio controlled LCD alarm clock did not set automatically on the winter time. After I push reset it started with January 1, 12:00 AM and I know no way to fix it. I have no manual, so I cannot find my way out of that situation. I found no model #, but a stiker saying 01 38
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 02, 2009
SOURCE: setting time/date on old Seiko
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
Thanks
Kashif
http://VintageDigitalWatches.com
Anonymous
  • Posted on Apr 04, 2009
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: How do I enable the alarm on the Eddie Bauer world
That was a the easy part for me - the big question is "How do you turn the alarm off?" Not Snooze, but literally turn it off so it doesn't ring at the same time every day?
Anonymous
  • Posted on Jan 26, 2010
SOURCE: Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Anonymous
  • 2501 Answers
  • Posted on Feb 25, 2010
SOURCE: I live in Eastern Time Zone. My atomic clock shows map of
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 • Watches
1helpful
2answers
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
1helpful
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 • Watches
2helpful
Setting time day date in ESQ Aerodyne
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
13helpful
3answers
SHARPER IMAGE -- M1600 / M1601 Swivel world time clock .
Push the mode button until the top window says 'Alarm', push the up or down button to shut off the alarm, push the Set button to set it.
Mar 05, 2009 • Watches
42helpful
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
