Vacuums Logo
Posted on Nov 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I must not be doing something in the correrct order. Is there a video showing how to thread the husqvarna serger?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Nov 06, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801960
Points
33142
Hello. Here is a video and an article on how to thread your serger http://www.ehow.co.uk/how_7412042_thread-husqvarna-serger.html
To see the video, click on the photo. Joe
4 thumbs up please. ty.
Singer profinish serger
This sounds like a timing issue. You need a professional.
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 • Vacuums
I have a white serger 1600 which I do not have the threading instructions. I have tried to thread it but cannot get the machine to work properly. help!
Here is the you tube website which has a 4 part video on using the
White serger 1600 machine: http://www.youtube.com/watch?v=5kF5ilPxR4Q
I also have a website with instructions threading this machine: http://www.ehow.com/info_8107633_instructions-thread-white-speedylock-serger.html
At the ehow site, you can search for all kinds of information in case you need more than learning how to thread and adjust the stitching. Happy sewing!
I hope this helps. If it does, I'd appreciate you vote. Thanks,
Handie Andie
Apr 07, 2011 • Vacuums
My Babylock Serger Eclipse was bought around 1994 and had a looper threading tool wire to thread it when I could not get it to thread manually. I lost the tool and can't get the thread to blow through....
Try one of the Serger looper threading tools listed on this Amazon.com page: http://www.amazon.com/Serger-Looper-and-Needle-Threader/dp/B000Q30C3G/ref=pd_sbs_ac_1 .
These are third party tools. See the main item and the section "Customers who viewed this item also viewed" for other manufacturer's looper threading tools.
I hope this helps.
Mar 21, 2011 • Vacuums
2answers
I can't understand how to thread lower looper (red) The instructions on the cover are very unclear
Sounds like you are trying to thread a serger or overlock. I would be helpful if you offered up the model number. However, a few things I've learned.
Sergers MUST be threaded in ORDER. Failure to do so will break your looper (had it happen)
In other words if you break one of the 4 or 5 threads... you have to un-thread all the other points and begin with Thread 1, then do thread 2, etc., etc.,
If you would give me the Make and model number of your serger... I will be happy to see if I can find your manual and threading guide for you.
Mar 11, 2011 • Vacuums
Pro 5 dc elna lock serger manual
I need instruction how to do roll hem on my pro 5 thread Elna serger 9000.
Feb 20, 2011 • Vacuums
Janome 6600 sewing machine. bobbin thread is gumming up underneath on a swimsuit knit type material (4 layers). Brand new machine had 1 1/2 weeks. Sometimes material goes down into the bobbin area jammed...
Make sure you're using a polyester thread (I use maxilock serger thread) then a stretch needle, and hold the tails of your thread until you get started into the seam so the fabric cannot push down into the opening on the throat plate.
Also, a small zigzag stitch (about 1.8 - 2.0 wide) is good to use on lycra as that will allow the fabric to stretch after the garment is made.
This is stuff I've used with my 6500P and other previous Janome machines in making Ice Skating outfits.
Oct 17, 2010 • Vacuums
I have a Baby Lock Serger Model BL4-605 Serger and can't find the Instruction Manual. Where can I find one? Also, I need a threading guide now, can you help?
I actually have the same model. I have the manual, but it is not very helpful. It does give instructions on treading, but not much else. You can download this manual online and it will cost at least $10.00.
Sep 13, 2010 • Vacuums
Serger motor won't stop running
the switch is stuck in the on position.replace the switch.sounds like you have something jammed up in the motor.openit up to get to the motor and see whats in there
May 04, 2009 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
