Had a broil element that caught on fire in a GE #JKP60G002 oven/microwace combo. Ordered part #WB44X173 to replace the broil element. When I removed the broil element I forgot to mark which wires went together. The broil element has two terminals however, there's three wires [(1)-red, (1)-black, (1)-blue. I'm not sure which two wires I should group together on the same terminal. I do have the wiring diagram from GE for the oven but I still can't figure it out.
Thanks for the help,
Levi
Hundreds of GE ovens, so can't give procedure, but problem is not necessarily the element - could be switch, connection to element, etc. Google GE (model #) lower element not heating.
the broil element doesn't get 240 volts,it's 120.also you should have the oven unplugged,pull out the element and read it out or at least one wire has to be removed from the part you're checking for continuity
If both baking and broiling element do not heath above
a certain temperature instead, then the part to be replaced is the
temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace
the element.
Before replacement the element can be tested
removing it from the cavity and reading Ohms at the element terminals,
with a multimeter set at Rx1. Disconnect power before removing the
element. In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
vetteman3002 responded quickly and was to the point
