SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: I have a panasonic cordless phone, model
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
SOURCE: I HAVE A PANASONIC PHONE MODEL KX-TGA641C AND ALL
Remove all power (wall and batteries). Ensure that the phone line is active and properly connected. Did they used to work? If so, check line conditions. If not, return for exchange.
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
