Does the unit work from its onboard controls or is this only a remote control failure?
If the latter...
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
thank u very very much sir for slove the remote control problem
i have done yours procedure then it can be sloved
thank u sir
how to display the multiple channels view running
is there any software we need.
i Have used TV plus software.In that multiple channels only viewing but not running the multiple channels. Only one channel running and others ideal
can u tell me about that for running the multiple channels
System not reponding to remote control.
Hello I recently installed the turner and it appears to be working fine, however I cannot use the remote. What must I do to resolve this issue?
Thanks
everything same... except wen my pc starts, it sez hardware not found or smthng...
my remote dont work too..?? how i can fix that??
