I have the service manual so I can get the part numbers and resistor information. What I'm looking for is which of all those resistors are the known ones to go bad. I have had several people respond with change the STK... convergence chips and the feeder resistors which I guess is the ones to the power lines. I'm not that good with schematics so I can't figure out which ones it would be. But if an expert whould reply R8C02 and R8C28 then I would know exatly which ones. I don't want to have to change all of them. Can you provide that detail?
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
I'm sorry, looking back it seems you already replaced the two STK chips, basically I can't be sure which resistors are bad, you should just test them all with a meter. I don't have the exact schematics for this particular tv and any resistor is a candidate for going bad. I hope this helps, I will see if I can find what ones commonly go bad but testing them is your best bet
email to [email protected] and I will have a look at it when I can, I am very busy this week with work and switching out an engine in my car so it may be a few days before I respond
It looks like the STK chips solved the issue. What happened after I replaced was they pulled off the heat sink and was over heating. My chasis the V7 has the 2 STK chips on a long single heat sink board. They are held in place via another metal cover with 2 screws. Something else to hold heat. Some other applications have seperate heat sink for each chip and has screws that hold them. So I removed the heat sink and then drilled holes for screws to hold the chips. I installed the heat sink and used screws to hold it to the circuit board since the plastic chasis was stipped. Then I screwed the chips to the heat sink and soldered the pins again. It appears to be working. We will see how long. If problem returns I'll ask my expert again.
Well I thought the STK chips detaching from the heat sink board was the issue when I re-attached via with screws. So I need to find the "feed resistors". You menitoned you did not have the manual for this chasis. I do. It is the V7. Is there a way to e-mail you the schematic or pcb .pdf's? Or attach to this issue on fixya? It must be one of those and I can't figure out which one. I attempted to test all the resistors and the ones I thought were the feeders measure the same as others on the board of the same type. What should I do?
