Groan?
Cooling fan, or harddrive.
Only two movable parts, besides the optical drive. (CD/DVD drive)
I suspect the cooling fan. Why?
Inside your laptop is a Processor. It, like the other hardware components inside, are cooled by air. That little fan is all that pushes air through the laptop.
Here, let me use a Toshiba Satellite C650 series of Notebook PC, as an example,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Scroll the page down, click on the photo next to Step 22.
Here you see the TOP of the cooling fan.
Close the photo. Scroll the page down, and click on the photo next to Step 24.
Fan Assembly removed.
That fan sits in bronze bushings. The bushings look like thick tubes, and the fan's shaft sits in those bushings. (One one top, one on bottom)
After time the bushings wear out. This allows the fan to c-ock over to one side. Plus makes a groaning sound.
Solution?
Replace the Fan Assembly.
One example,
http://www.laptopking.com/kingpartdetails.asp?ref=1443&category=fanNow, am I stating that THIS is the problem?
NO.
I am stating this is the first place to start.
If the laptop is dirty inside, it is almost a sure bet that this is the problem.
Why?
Because if the fan bearings are dry, and worn out, the fan will not operate as it should. It will spin slower than it should, and may have periods where it just stops altogether.
This allows the Processor to overheat. When a Processor overheats it turns off. (BIOS turns it off)
This is a fail safe feature built-in. Keeps the Processor from burning up.
No Processor operating, no computer.
Want to replace the Fan Assembly yourself? No prob! Doesn't take a rocket scientist. (Sorry Gort)
HOWEVER, there is a PROPER procedure. Post back in a Comment, that you want to replace it yourself, and I will guide you.
{Plus you will be cleaning out the inside of that laptop }
Regards,
joecoolvette
[ Article first page,
(Page numbers are at the Top, and Bottom of the page, in white.
Page1 :: Page2 :: Page3 :: Find another model )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
