I have this cable adapter which is CA-62 . they said that this adapter is compatible with my phone but everytime i plug this to my phone my phone says 'data enhancement not supported' what should i do?
i have the cable adapter which is CA-42. but when i connect my phone with my pc then pc shows that it is an unknwn device. so what should i do?
do?
AnonymousJul 26, 2008
i have this cable adapter which is CA-62 . they said that this adapter is compatible with my phone but everytime i plug this to my phone my phone says 'data enhancement not supported' what should i do?i have this cable adapter which is CA-62 . they said that this adapter is compatible with my phone but everytime i plug this to my phone my phone says 'data enhancement not supported' what should i do?
i have nokia 6020 but when i connect data cable of ca 42 it shows enhancement not supportes...help...i have nokia 6020 but when i connect data cable of ca 42 it shows enhancement not supportes...help...
AnonymousDec 03, 2008
WHEN I CNNECT DATA CABLE IT NOT CONNECT TO NET
You can't post conmments that contain an email address.
Are you sure is is a 'PC 10'? I can't find that model. All the ones I have used were battery operated desktop use or hand held. Is this a cable that connect the label maker to a PC, so you design on the computer and print to the Dymo? If that is the case, It _should_ be a standard printer lead.
Best Buyhttps://www.bestbuy.ca > ... > USB Cables
NiceTQ Replacement PC/Mac USB Data Sync Transfer Cable Cord For DYMO Label Writer 450 Twin Turbo Label Printer. Model Number: 308139549170. Web Code: 14840651.
· ‎In stock Dymo PC 10 search results.
get correct cable which is compatible with your cell phone,you can check which cable type is compatible with your phone on nokia website by selecting your phone model,write down cable model then check its on your local shop or you can buy its from ebay
There is two main ways that you can transfer photographs to your laptop;
USB 2.0 Full Speed for rapid music transfer
Nokia Connectivity Cable CA-101 - High-speed data transfer This
micro USB cable provides high-speed USB 2.0 data transfer rates, and
enables charging your compatible device or enhancement from a laptop or
PC USB port.
Bluetooth 2.0 with stereo audio profiles for wireless music listening and control.
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode." and select from the
following options:
• Nokia mode — to use the device for PC Suite
• Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
• Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
• Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
• My phone's visibility — to define how your device
is shown to other Bluetooth devices
• Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
• Active devices — to check which Bluetooth
connection is currently active
• Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
• My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
6070 support ca-42, so what exactly u mean, it doesnt recognise your phone (restart phone once and plug it back to pc), or it doesnt detect modem (you need to manually add nokia 6020 cable modem, there are no 6070 modem drivers for ca-42) ??
do?
