How do I know if the buzzing noise I am getting from my tv is the cooling fan or color wheel? Can these be changed independently of each other and can I do it myself?
The buzzing is most likely the fan. A low volume intermittent screeching (like when a small motor needs lubricant) is probably the light engine. It also may have a really wacky picture with the sound.
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
It is either the color wheel or a fan. To isolate the color wheel, remove the back cover and make sure you put the lamp door back on so that the door interlock switch is activated. Turn the set on and get the picture and humming noise going. Just to left of the rear fan there are some wires. One is a really flat brown or rust colored ribbon cable that plugs in to a board on the left of the wires. This is the color wheel ribbon. When you unplug it the set will keep going for a moment or two but if the noise stops, you will know it is the color wheel. Don't be alarmed because the set shuts off with this ribbon disconnected. Just let all the fans stop (for proper cooling) and then unplug the set for 5-10 minutes. If the humming did not stop you have a bad fan motor. Plug the little ribbon back in while you have the set uplugged. Plug the set back in and turn it back on and try to isolate which fan it is, if it is a fan. If you determine it is a color wheel, the light engine will have to be replaced as Toshiba does not offer just the color wheel. If it is a fan, those can be replaced. I hope this helps. Let me know what you find and thanks for using fixya.
The wiring may have fallen back onto the fan or that may never have been the problem at all. A common problem for DLP TVs is the color wheel motor. It will hum and change pitch especially as you power the TV on or off. Its an expensive repair in this TV because Toshiba does not sell it independently from the larger, more expensive light engine assembly. Don't allow this to fall out of warranty! Call the extended warranty company and tell them that the repair was not effective and that you want this resolved promptly before the warranty expires.
Sounds like you have a bad color wheel if they tell you it's not available but only with the engine you can get just the color wheel there are vendors just for hard to get parts
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
More than likely its the color wheel there is a bulletin from samsung indicating that a loud buzzing is often related to the color wheel.Let me know if you need to know where to get a color wheel and I will post a link, just include your full model number.
i constantly hear complaints about fan noise in dlptvs
if you sit in front of your computer you will hear the same noise
even in the next room
there is no solution to the fan noise problem
this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product
it can be noticeable if the tv is on hard surfaces
ie wood floors ,inthe corner, glass top etc
the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube
its kinda like annealing glass
its designed to extend the life of the lamp ....
which im sure youve priced
call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it )
they are also improved
this product is known to have short bulb life
sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement
( not cheap)
toshiba will not piece out the color wheel assembly individually
