Check
Windows services. Right Click My Computer and Manage. Choose Services
and Application > Services. Choose "Windows Audio" and set to
Automatic and Start.
Now next you can do is
If
you open control panel & click device manager the window that opens
will show a list of all installed hardware. Look for anything with an
exclamation mark beside it, or to do with sound. If you see anything,
right click it, check it isn't Disabled then select "Properties." The
next window should have some tabs along the top, the one you are looking
for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check
ur registry. Check if the sound registry key is enabled or disabled.
There could be an error in registry, run registry cleaner reg in out to scan for
errors.
