I have windows vista on my toshiba satellite x205-s9349 and am wanting to put windows xp on it so i can play some games that are not vista compatible. i need to disable the sata in the bios but unable to
Installing Windows XP on a SATA Drive
Author: DJ Oslo
Date: August 18, 2007
Description:
This tutorial will describe step by step how to install XP on a laptop with a SATA hard
drive in order to downgrade the operating system from Vista to Windows XP SP2. The
laptop model that this tutorial is based on is listed below:
Model: Toshiba X205-S9349
In order to install XP, you will need the following software:
Windows XP SP Installation CD
nLite (http://www.softpedia.com/get/System/OS-Enhancements/nLite.shtml)
Introduction:
If you want to downgrade to XP from Vista you may run into a problem during the boot
stage of XP Installation. The problem I encountered was a message that read:
“Setup did not find any hard disk drives installed on your computer”
The problem is that XP does not provide the necessary drivers for the SATA controllers
and as a result it won't detect the SATA hard drive. You could use an external floppy
disk drive but that might not guarantee success.
What has been suggested is that you perform a procedure called "Slipstreaming".
Slipstreaming is the procedure where you create a new build of the XP installation files
and "merge" the drivers you need for the SATA controllers. You would then use this
new build to install XP onto your system.
Note: These procedures were performed on my Toshiba P105 laptop, which is my current
working laptop.
Step 1.
Create a directory under My
Documents where you will
copy the contents of your
XP installation CD.
Step 2.
Download the SATA driver that you will need in order to “Slipstream” into your XP
installation.
The following link is to the SATA drivers that will work with the Toshiba X205-S9349.
http://209.167.114.38/support/Download/files_Downloads/pspb7c/Intel-Matrix-Storage-Manager-V1.0.0.1082.zip
Step 3.
When you download the .zip file,
unpack the contents in a new
directory under My Documents.
Step 4.
Open nLite and locate the
directory where you copied
the XP installation files to.
Click on the Next button.
Step 5.
You will get information on the
Product. Click on the next button.
Step 6.
Step 7.
In the Task Selection, you will click on
the button called Drivers and Bootable
ISO. After you click on each button the
red dot will turn green. What this means
is that you will “integrate” drivers into
the installation and then create a bootable
ISO file.
Step 8.
Step 9.
Click on the Insert – Multiple driver
folder option to select the drivers that
you will integrate.
Locate the folder where you
unzipped the SATA drivers.
Highlight the folder and click OK.
Step 10.
The following drivers will be listed.
Note: you must select the correct driver to
integrate or else you may experience errors
during the installation phase of XP.
Select the first driver.
Click on the OK button.
Step 11.
Select all the items to
integrate. Click on the OK
button.
Step 12.
Step 13.
Highlight all the drivers and click on
the Next button.
Select Yes to start the process.
Step 14.
nLite will now apply the changes
to the installation files.
Step 15.
When complete, it will display how
much the installation grew. Click on
the Next button.
Step 16.
In the Bootable ISO section, click on
Make ISO.
Step 17.
Step 18.
You will be prompted to save
the ISO file. Select where you
want to save it and click on the
Save button.
nLite begins the process of
creating the .ISO file that can
then be burned to CD and used
as the installation file for
Windows XP.
Step 19.
You should get a message
that the ISO file has been
created successfully. Click
on the Next button.
Step 20.
Step 21.
Open your CD burning software. In this example I will use Nero Burning ROM.
Customization is finished.
Click on the Finish button.
In the menu bar, I select Recorder – Burn
Image…
Step 22.
Step 23.
I locate the ISO file that I created in
nLite. Highlight the file and click on
the Open button.
Click on the Burn button. This will now
burn the ISO to CD and thus create your
new XP installation that will install the
SATA drivers during the boot stage of XP
installation. this is 100% working thank very much
Author: DJ Oslo
Description:
Introduction:
working laptop.
Step 1.
XP installation CD.
Step 2.
installation.
Step 3.
Step 4.
Step 5.
Step 6.
Step 7.
ISO file.
Step 8.
Step 9.
you will integrate.
Step 10.
Step 11.
button.
Step 12.
Step 13.
the Next button.
Step 14.
Step 15.
the Next button.
Step 16.
Make ISO.
Step 17.
Step 18.
Save button.
Windows XP.
Step 19.
on the Next button.
Step 20.
Step 21.
Image…
Step 22.
Step 23.
the Open button.
installation.
I not understanding why you would disable the serial ATA plus new harddrives runs off Serial ATA. You can still install windows xp. Just make sure that the drivers are compatible. If not you can install windows xp and if it notices that something is incompatible. Then you will have to locate the driver on the manufacturers website.
Will this work on X205-S9359,If not where can I find driver for mine,thanks,any help appreciated..jp
cant install window 7
