You put disc back in the camera
and then finalise it?normally on DCR-DVD905 you go to the options> finalise
then you take the mini disc out and can use it on the PC
if you took the mini disc out before finalising it you may have corrupted it.
There is an option to un-finalise it if you wish to add more data later
The open session needs to be closed before you can read the DVD on the camcorder or on a PC.
- Download the free DVD Decryptor from the link below and install it on your PC...
http://www.dvddecrypter.org.uk/
- Load the miniDVD disc into the DVD Writer in your PC and click Tools > Drive > Close and then choose Track/Session/Disc (Try the three options in that order)
- Once the track or session is closed you should be able to read your data.
if that doesnt work
Try
to use a cotton swap to 1st clean the recording lens or blow gently on
it. Place an empty disc in, format the disc, record a little scene. Turn
off camcorder. Place the error disc in the camcorder, turn on the
camcorder all the way to play/edit. If this doesn't work turn it to
record and try to record.
If the error still persists, the disc has not been finalized which is usually fatal for the recorded data!
In
that case, you still have a chance with isobuster (which is not free)
though recovery is not alwasy guaranteed. Here is a link you might like
to check out...
http://www.isobuster.com/
