Cars & Trucks Logo
Posted on Sep 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is fuel pump at for a 1985 cadillac deville
Anonymous
Level 3:
President:
  • Master 1,190 Answers
  • Posted on Sep 10, 2010
Anonymous
Master
Level 3:
President:
Answers
1190
Questions
0
Helped
488094
Points
3636
The fuel pump is in the gas tank. Disconnect all hoses and electrical wires from gas tank. lower gas tank. Remove ring that secures the fuel pump assembly and pull assembly out, be careful not to damage fuel float assembly. When replacing fuel pump, replace the sock and the fuel filter.
I have an 88 Cadillac Deville. 2 months ago I had a new fuel pump put in. It's making a whining noise and the car keeps dying and sputtering. What else could be the problem to make the pump go out?
Cadillac DeVille Questions - My deville has been stalling ...
www.cargurus.com > Questions > Cadillac > DeVille
CarGurusJun 25, 2013 - My deville has been stalling while driving when I let off gas. ... mapp sensor, maf, spark plugs, valve gasket covers, fuel pressure regular and still dying. ... 1989 Cadillac DeVille car stalls or stops what does that mean ... my 93 deville has began spitting and sputtering and lossing power air and fuel filer has ...
My car started sputtering when I was driving and just died. I ...
www.cargurus.com > Questions > Buick > LeSabre
CarGurusMay 25, 2014 - My car started sputtering when I was driving and just died. ... no- don'tkeep guessing- take it to a good mechanic in a good garage- "good" meaning, they won't be guessing- maybe you can fix it .... Used Cadillac DeVille".
Rough Idle Due to EGR Valve Sticking Open : Cadillac ...
repairpal.com > Problems > Cadillac > DeVille
1985 deville
pull the pump clean it and the line then try
1985 Cadillac Deville, the fuel pump stopped working. Replaced it and found out it wasn't the problem. When i turn off the ignition and pull the keys the dummy lights stay on (check engine, alternator,...
no, check all fuses in fuse box and under dash below glove box. sounds like there is a fuse that has been "blown" will need a wrench or socket driver to access RH fuse box.
Where is the fuel pump reset button on a 1985 cadillac deville?
There is no reset button for the fuel pump on a 1985 Seville. You most likely need to replace the fuel pump.
I have a 1985 cadillac eldorado blitezz where is the fuel pump relay fuse
Its in the main fuse box under the hood pop the cover off and read the inside it will tell you which fuse is the fuel relay.
1helpful
How to replace1989 cadillac sedan deville fuel pump
TO replace the fuel pump, remove the gas tank. When replacing the fuel pump also replace the strainer on the bottom of the pump and replace the fuel filter.
I have a 85 deville 4.1 won't start
check the ignition module to coil or you have ecm problems. have it scan.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
