Pentax Optio M20 Digital Camera Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i download the photos and unplug the leads etc I go to turn the camera on and the little red light turns on on the front of the camera and the camera wont turn on, what can I do?
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Sep 03, 2010
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1215870
Points
16135
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
2helpful
Will not download pictures from camera to computer
I have the same camera. The little red light flashing is normal. It should flash for about a second and then go out. I believe the camera is reading the SD card during this time. If you turn on the camera with no SD card present this light should not flash. It sounds like you’re having problems transferring pictures from your camera to the computer. I'm guessing you’re using the USB cable that came with the camera to connect to the computer. I don't have an exact fix for this problem; it could be a defective cable or connector. However, I do have an alternative way for you to download your photos that I believe will work even better for you. Buy one of those mini SD card readers with the USB port adapters. The one I have is made by SanDisk and is called the MicroMate. Here's a link so you can see what it looks like. http://www.sandisk.com/Products/Item(2018)-SDDR-113-A11-MicroMate_for_SDHC.aspx When you want to download your photos just unplug the SD card from your camera, insert it into one end of the SD card reader, and plug the other end into a USB port. The computer recognizes it as a flash drive. Then you can just copy from one drive to another. I find it to be much faster then using the USB cable to download photos. I hope this helps you out.
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
2answers
Turn off Red-Eye reduction
Hi - You can download the manual from the link underlined in blue below:
FinePix F10
See page 37 to turn off red eye:
2answers
Error Message
Have you tried resetting your camera? To reset your camera, open the battery cover and you should see a small hole inbetween the SD card slot and the battery release switch. Then use a small narrow object (i.e. mechanical pencil with its lead extended) and press into the hole. You should feel it "click" and then hold it for about 3 seconds. Try restarting your camera.
Note: Please backup all the data on your SD card before doing this.
Hope this helps
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
3answers
Innovage digital keychain - won't turn on
How did you get it to download to your Mac are using Mac OS X.5?  I am using 10.5 and the program just quits on me... I have not been able to download any pics at all.
Thanks for your help.
3helpful
2answers
Frozen in the boot zone
I just had the same problem and "fixed" it. I read the other solutions and while the camera was on I gently inserted a tiny probe in the hole on the front of the camera, then [camera is still on] I reset the camera with the same probe on the reset hole in the back of the camera.
This fixed the problem immediately. I know the questions were years ago but there is no Concord site now and I thought I would help.
My theory on how the camera got that way is that I might of had my finger over the lens while powering up and prevented it from coming out - maybe there is a "trip" switch to keep the little motor from burning up in that situation and you reset the switch thru the front hole? Anyway that worked for me and kept my [for years] great little camera, with lousy instructions on use, working.
Thanks to whoever runs this website saved me money $$$$$$!!!!!!
Not charging?
hi here is the home page of your camera download its driver and read the manual : http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=Digimax+i5+&x=42&y=10 i belive the problem is the connection between the metal surfaces in the camera and the metal tabs in the deck make sure the tabs are upright and elastic (after many uses they squashed a little) good luck
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
