I have a dell laptop with windows xp pro and connected to a shared printer in the network. When i print something the spool runs successfully but page comes out blank. Other users are able to print successfully from the same printer. Please HELP !!I have a dell laptop with windows xp pro and connected to a shared printer in the network. When i print something the spool runs successfully but page comes out blank. Other users are able to print successfully from the same printer. Please HELP !!
You can't post conmments that contain an email address.
Try the document I linked below. It tackles blank copies which is close to what you are experiencing. Scans or Copies Are Blank
Hope It's resolve all Your HP Printer Problem,
Or
Are you getting a error code? Are you getting a blank copy ? If you are getting a blank copy it may be that you have a blown scanning lamp. Also, when was the last time the corona wires were replaced? They may need to be replaced?
It is not the toner. There are 2 things you can try yourself, anything else requires service. First try opeing and closing the right hand side door. Try this several times if necessary. There are contacts in this door that sometimes don't make contact and opening/closing the door will sometimes resolve blank copies. The other thing you can try is remove the toner then pull out and reseat the drum unit. Here again there are contacts that need to be made that can cause blank copies.
Good Luck and Thank You for using Fixya.
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
