SOURCE: On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
Check your venting. Insure it is not clogged as this can cause the unit to stick at 6min mark. Just before the cool down period.
Sgt Lauder
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
SOURCE: My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
SOURCE: whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
