20 Most Recent Whirlpool WED94HEAW Duet 10 Cycle Front-Load Electric Dryer With 7.4 Questions & Answers
Circuit breaker?
Do you mean the main RCD/ELCB or the MCB (micro circuit breaker) protecting the circuit.
The MCB is the modern replacement for a fuse...
If it is the main RCD that is tripping it indicates a current leakage to ground that might be in the power outlet or coincidentally in both appliances. If the appliances work ok on other circuits the fault is likely with the power outlet.
If it is the MCB that is tripping and the appliances work ok in other circuits, it indicates the MCB might be faulty.
Whirlpool Dryers | Answered 2 days ago
you can google your question for answer , to this or any other question.
It is 220Volt AC
Whirlpool Dryers | Answered on Jun 09, 2019
is it 220? if so the 2 black wires need to be switched
Whirlpool Dryers | Answered on May 30, 2019
No idea what you mean by "reset". I expect you pull the plug and that will be it.
Whirlpool Dryers | Answered on May 19, 2019
It probably isn't shutting off because either the thermostat isn't working or the computer isn't switching it off because it is faulty or isn't receiving temperature information from the sensor in the wash tub...
Whirlpool Dryers | Answered on May 08, 2019
Depending on the year, the f1 code may be a control board failure code. Board can be replaced or in my case a 15 or so minute fix by soldering one of the blown out solder joints on the board. If you decide to check the board yourself, unplug the unit before disassembling. If it is the solder joint it will be very evident which one has fried once you take the board out.
Whirlpool Dryers | Answered on May 02, 2019
Depending on the year, the F1 code is a control board fault. If the dryer does not start (clicking noise heard but drum does not start) it may be a solder joint on the board has cooked. If you are handy it is a 15-20 minute fix.
Replace the thermal fuse . A small white plastic piece on the blower housing with 2 wires going to it .
Whirlpool Dryers | Answered on Apr 30, 2019
Whirlpool WED94HEAW Duet 10 Cycle Front-Load Electric Dryer With 7.4 Logo
0 questions posted
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
lg tromm stackable washer dryer working
  • Dryers
