I will try one. The original cable is a new 50ft gold plated DVI cable just as an FYI. I will report my findings soon. Thanks.I will try one. The original cable is a new 50ft gold plated DVI cable just as an FYI. I will report my findings soon. Thanks.
You can't post conmments that contain an email address.
Hello there: The best way to describe this is what is called screen burn in. this is very common on screns that have games or pictures that arre displayed for long periods of time without being shut down just like on a computer screen when a screen saver is not used . there is nothing wrong with the bulb. the yellow that you are seeing is actually burned into the glass part of the projector and the lense so if you can and feel like you can dissasemble the projector dissassemble it and locate the glass and see if you can get the yellow tint that will be on the glass and the lense off by using some rubbing alcohol and a cottomn swab But if it wont come off you will have to replace the lense and the glass ok Hope this is very helpful for you Best regards Michael
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
Using the remote control, hold down the power off button for 30-45 seconds
This will reset the status button, removing the red light
Power up the projector and select Menu
Select Projector Options
Select Set-up – a number of tabs will appear called pages
Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
I had one with the same issue. After checking and rechecking the projector, I found that there was a lose conection between the CPU and the RGB output connection. It's really touchy.
if the projector is an lcd projector, the heat has caused burn spots on the light filter on the blue lcd. that needs to be replaced by the manufacturer. if it's a dlp projector, there are heat marks on the optics somewhere. also needs to be looked at by the manufacturer. nec, toshiba, and smart won't sell parts, so you'll have to send it in.
there is a light filter on the blue lcd panel that is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical emgine.
hi everyone i have the some yelow problem with CANON lv s3... any ideas where can i found this blue lcd polarizer...e-mail me sugestions [email protected]
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
