Question about NEC PlasmaSync 42MP3 42 in. Television
Onida TV service code needed
I wanna to restore factory setting due to noise disturbance in my Onida black TV
Posted by krantikala on
Anonymous
  • 52 Answers
Press disp+vsm together here it opens service menu at last of that menu there is restore option press 1 to INT . press 1 and your tv will restore.
Posted on Aug 11, 2009
muruganandam
    New Friend:
Servise menu passward
Posted on Oct 03, 2012
jagguj26
    New Friend:
No sound for onida tv model no c014esp1120b
Posted on Apr 10, 2011
vandana samudrala
    New Friend:
Iam getting that tv is busy
Posted on Sep 06, 2016
pahbwa
    New Friend:
  • 4 Answers
Gems ore for free and not free
Posted on Mar 01, 2015
sumit verma
    New Friend:
When I am on my TV it want to a renter lock key with black and blue screen plz slove this proplem
Posted on Nov 09, 2013
  • Sudhir maharana Jun 08, 2015
    onida default password-5963,other is-1147,and 8888 try it, this may help u
Vinod Sardeshmukh
    New Friend:
I use onida ky2 21" My brightness is full (up to optimum ) but I am getting dark display If if give punch to tv sometimes its brightness is normal else again it goes black please help
Vinod Sardeshmukh 9270571589
Posted on Apr 27, 2013
Onida 32" LCD TV
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 14, 2017 | Televison & Video
Onida ky thunder OXYGEN 29"
Check its 'S' correction setting. You have to enter its service mode to do this adjustment. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 13, 2013 | Televison & Video
I need to restore my Acer T690 to factory setting. The acer had problem booting so I used windows XP bootable disc and it had replaced the operating system. I have recovered my data. Now I need to restore...
Assuming the Recovery Partition hasn't been disturbed, boot the machine and press ALT + F10 at the same time. You will enter a recovery phase that will give you the option of restoring to factory settings. If the Recovery Partition HAS been either disturbed or wiped out, you will not be able to restore to Factory Settings without a set of disks from Acer.
Feb 17, 2011 | Acer Aspire T690 (AST690UP820A) PC...
My onida 21" black color
Possible there is a fault in soldering. Poor joints in the CRT base circuit of the CRT tube will result in poor connection after some use due to the fact the heating and cooling will detach off the leads. So use a good soldering iron to touch up all the points in your main board and the CRT board and it must work provided your tube is not faulty.
Feb 07, 2011 | Televison & Video
Latest onida tv service code for remote
sir ineed the service menu code for onida tv remote model is rc 115/d
Nov 14, 2010 | One For All URC-3445 Remote Control
Wanna restore my laptop to factory settings vaio vgn-n320e
Hello
At the link below you will be able to get step by step instructions on how to restore your computer to the original factory settings.
Click HERE to navigate to the page.
Kind regards
Andrea
Aug 14, 2010 | Computers & Internet
How to get LOT identification number for ONIDA black 300 21 inch TV
BSC25-NO347 E1MWFL21017 , i have onida black 300 21" tv - in that LOT no is given as shown above - iam babu , computer hardware engineer, from bangalore,9986222774, - i have replaced LOT in my tv - please cal me immediately - i also need very big help from you
Mar 30, 2010 | Televison & Video
Due to high voltage my Onida Television got
the power supply filter condensor got leaky in ur tv,,,,,
well it will cost 80 rs... the picture will wave ,, call a tech person to change it. value of condensor 150mfd 450v
Mar 23, 2010 | Televison & Video
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
NEC PlasmaSync 42MP3 42 in. Television Logo
2,127 people viewed this question
Top NEC Televison & Video Experts
Ekse
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
