FixYa.com
NEC VT47 Multimedia Projector
All Products > NEC > Multimedia Projectors
Problems with NEC VT47 Multimedia Projector?
Troubleshooting and Support
Solved Problems for NEC VT47 Multimedia Projector RSS Feed Post a New Problem
Status light blinking red
The status light is blinking red every .5 second at .5 second intervals for 6 cycles. The power light is solid orange....
2 Solutions
Blinking status light
2 Solutions
NEC VT-47 picture problem
I have had my projector for several years with no problems. Now I'm getting some Blue blotchy areas in the picture. I...
1 Solution
NEC VT47 Blink Sequence but not comming...
Hi, My NEC VT47 Projector stopped working and I now get a blink sequence at power up. I thought the bulb might have...
1 Solution
NEC Overhead Projector
We have a NEC overhead projector that we use at our church building. The bulb burnt out and we replaced it with a new...
1 Solution
the picture shows dark
picture is showing a little fuzzy and a little dark even when brightness is up all the way. please help
1 Solution
Re: missing manuel
I am a library media specialist at a school and the manuel for this projector has walked off and not returned. Sad LMS,...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC VT47 Multimedia Projector RSS Feed Post a New Problem
nec password
i lost my password and now my projection is locked i have the nec LT 265 projection
Post a Solution
Unable to reset VT47 after lamp and filter...
The lamp exceeded the hours of service and after replacing the lamp and filter I cannot reset the projector by holding...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness1500 ANSI lumens
Contrast Ratio400:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)24.8 in. - 300 in.
Screen Distance1.97 ft. - 23.95 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 100 kHz
Synchronization Range Vertical50 - 120 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Operation Noise32 dB
Interfaces
InterfaceSerial (RS232) · Infrared
Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Composite Video
Lamp
Light Source Life3000 Hours
Other Features
Special FeaturesOn Screen Menu · Keystone Correction
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
HDTV Formats720p · 1080i · 480p · 576p · 480i · 525i · 525p · 750p · 1125i · 625p
Warranty
Warranty3 Years, 6 Month on Lamp
Dimensions
Depth10.24 in.
Height3.66 in.
Width11.57 in.
Weight6.39 lb.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
