Dell Inspiron Mini 10 Notebook Logo
Posted on Aug 28, 2010
I have BSoD on my dell inspiron mini error code 0x0000007B. i have read several posts telling me to download various types of repair programmes. How do i get rid of the BSoD to enable me to download such programmes. I have tried Ctrl + F11 but doesnt work. help!!!
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Aug 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
125398
Points
86
Try installing ubuntu to at least get you up and running so at least you can surf the web and check your emails etc. Then either try a windows repair disc or see if trinity restore has an options to fix your os.
0x0000007b error
The BSOD is generally caused by driver issues, viruses, and hardware failure. It would seem you are able to use the computer after the BSOD if you are posting on that computer. With no further information, FixYa cannot help you more.
1 long beep 2 short beeps
Hello Hardyjosef,
Below is the beep code chart for the mini 10 systems.
No POST
If the system does not perform a Power-On Self-Test, there are various things to look for:
1.Check that the system has a power light.
2.If the system has no power light, ensure it is plugged into AC power. Remove the battery.
3.If the system has power but is not performing a POST, Check for one of the following Beep code errors.
Beep Code Description Failure Coverage
1 BIOS ROM checksum in progress or failure. BIOS Chip Motherboard Failure or ROM Error
2 No RAM Detected No Memory Detected
3 Chipset Error (North and South Bridge Chipset, DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard Failure
Time-Of-Day Clock test failure.
Gate A20 Failure
Super I/O Chip Failure
Keyboard Controller Test Failure
4 RAM Read/Write Failure Memory Failure
5 RTC Power Fail. COMS Battery Failure
6 Video BIOS Test Failure Video Card Failure
7 CPU Cache test failure CPU Failure
8 LCD LCD Failure
4.With the power off and the system unplugged, remove all CRUs from the system and reconnect the AC adapter to the system and try again.
Try reseatting the memory to see if that will resolve the issue. If not, the motherboard may be bad and will need to be replaced. If you need another motherboard you can call the Dell Spare Parts Department at 1-877-717-3355 to purchase one.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
2answers
2answers
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Systems freezes when in Windows - locks up after units logs in
d_winrow
In regards to getting the BSOD there are several things that the 0x0000007b error can point to. To help me better see what is going on I need to know the error code message too. The link below will show you how to get it.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Windows xp tries to start in safe mode screen then as program starts gets brief blue screen then back to safe mode start selection screen once again this keeps repeating
your system will do this as it has shut itself down to protect itself, to make the blue screen stay on so you can write down the error code (e.g stop 0x0000007B),you need to choose the option of `disable automatic restart on sytem failure` (this will be on safe mode screen, reboot, then when you get the B.S.O.D it will stay on and display an error code, google it and you get the answer or post the code on here and i`ll tell you
Dell Inspiron 6000, Windows XP. Page Fault Error. Laptop died with BSOD indicating Page Fault error. Won't start in normal (BSOD) or any of the safe modes (hangs while loading drivers). Any ideas?
This appears the be a RAM memory read error. Try removing one of the memory modules, and run the system see if the error still occurs. Then try the other module. If issue is only associated with 1 module, replace that one.
Memory can be purchased here: www.crucial.com
Dell Inspiron E1505 I get the BSOD even after using the recovery disc STOP: 0x0000007B (0xF7A2C524, 0xC0000034, 0x00000000, 0x00000000) what should i do
Run a diagnostics.
Make sure laptop is off.
Press and hold Fn key and press power button at the same time.
The PSA test will start and it will give you display test first then after the memory and hdd test. complete the test and wait until it gives errors like 0141 / 0142 / 0146.
If you get one of these errors try reseating the hdd. Then run again the test. If still fails then replace the hdd.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
