Canon PowerShot SD1100 IS Digital Camera Logo
Anonymous Posted on Aug 26, 2010
Can I erase more than one picture at a time? It only lets me do one and doesn't ask "erase all?" like some cameras do.
Catalin Turcu
Level 3:
  • Canon Master 4,924 Answers
  • Posted on Aug 26, 2010
Catalin Turcu
Canon Master
Level 3:
Answers
4924
Questions
0
Helped
1232144
Points
13383
If you want to erase all ..just get to the menu ...storage ..and memory card ..and choose format ..this will erase all into the camera and format the card again which is a good thing in case you had errors..
anyway ..in the view mode..it has to have something called multiple deleting or erasing ...and in there you can sort the pictures by name and delete them all at once ..
Testimonial: "Thanks - your solution worked!"
3helpful
2answers
I accidently erase all the pictures on my camera memory chip. I did not save the pictures anywhere how can I get the pictures I erase ???
I have had success with this camera pic recovery software called asoftech photo recovery, here's the tutorial
http://www.youtube.com/watch?v=BC0Yo4XN6Mw
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
1helpful
I have a Canon Power Shot A580 i just want to erase some photos from the camera thats it
Put the camera in picture review mode. Then use the zoom to bring up thumbnail diplays. Use the up/down, right/left buttons to navigate to the individual picture that you want to erase. Then press the "trashcan" button on the back of your camera. Select yes when it asks if you want to delete this picture.
Alternately you can delete all the pictures by again selecting picture review mode, pressing "menu", then scrolling to "erase all" pictures.
Deleting images
Generally your camera will have a main menu, which lists this as an option.
Look for a menu button on your digital camera. While the camera is on, press this button, and cycle through the options that appear, watching for a listing which says something like "Erase all".
Usually there will be another button or set of buttons that have arrows on them, and let you move up and down among the listed options. Press the up or down button (or the right/left button, whichever applies to your camera), until the "Erase all" option is highlighted.
There should also be a button on your camera that says something like "Ok" or "Function Set"; no matter what it's called, the important thing is that it is NOT one of the buttons which either opens the menu listings (the one I'm describing as the "menu" button, regardless of what your camera calls it), or moves between menu items (the up/down/left/right buttons). Once you have found the menu item for "Erase all", and have highlighted it, press this button.
You will probably get a message asking you to verify your choice, since once the photos are deleted from your camera, you won't be able to retrieve them, so most cameras will ask you to confirm any erasing you do, whether it's just one picture, or all the pictures in your camera's memory/storage. You confirm the deletion by pressing the same button that you used to start the deletion process.
So, to recap:
1) Turn the camera on.
2) Find and press the "Menu" button.
3) Find and press the arrow/next button until you see a menu item saying something like "Erase all".
4) Find and press the "OK" button -- or whatever button will get the camera to accept the menu item selection you've made.
5) If the camera asks you to confirm your choice, use the arrow/direction keys to highlight the "Yes" or "OK" option in the confirmation window.
6) Press the same button you used to start the process ("OK" or "Function Set"), one more time to confirm your choice.
7) The camera should now delete all of the photos in its memory.
WARNING: DO NOT DELETE YOUR PHOTOS UNTIL YOU'VE DOWNLOADED THEM, UNLESS YOU ARE ABSOLUTELY SURE THAT YOU'LL NEVER WANT THEM. It is always better to have an extra backup of your pictures than to permanently lose something you can't replace.
If anyone else has used the camera, it's best to check with them to make sure that they've downloaded their pictures off of the camera, before doing a full delete of all pictures on the camera.
Most cameras will also let you individually delete pictures that came out badly, or where you accidentally took a picture you didn't mean to take. If you're not sure what else is in the camera's memory, it's always wisest to use this method, instead of deleting all the pictures at once.
Apr 02, 2009 • Cameras
4helpful
Delete one picture at a time
Put the camera in picture review mode. Click through the pictures until you find the one you wish to delete. Then press the trashcan button on the back of your camera to delete just that picture. Select OK if asked to erase this picture.
Erases pictures from camera
Hi - You can download the manual by clicking the link underlined in blue below:
FinePix F30
See page 81:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Deleting one picture
Put the camera in picture review mode. press right and/or left to find the picture that you wish to erase. Press down (see the little trashcan just below the down button?). It will ask you if wish to erase, select yes.
When trying to upload pictures to my laptop i am asked to format my card, however this requires erasing all of my pictures. Is there anyway to get my pictures off my camera before formatting? When...
one solution that I can suggest is to make a CD photo,take the memory card to a store where they have the photo computer and make a CD ( walgreens , sams , K mart ) hope its helpful
1helpful
I want to erase a video, but not "erase all images"
Careful, the way you're doing it would actually erase everything. Use that way only after you've downloaded all your pictures and videos to your computer.
The way to erase a single image or video is to go into picture/video review mode. Advance so that you can see the video you want to delete on your LCD screen. Then press the "trashcan" button on the back of your camera once. It may ask you "delete this video?". Select "yes".
2answers
Deletion of unwanted pictures
You need to right click on the photo and select delect.
When asked if you are sure select yes.
Memory
you need to go through the cameras menus and look for the word format. choose this and confirm Yes if it asks you to. this will erase everything and let you start over.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
