I assume you mean just the bulbs:
Thank you,
Lee
SOURCE: DRIVE BELT ON 2002 TOYOTA CAMRY
If you are referring to the vehicle having a "Timing Belt", no, it does not have one.
The 2002 Camry 4 cylinder has a Timing CHAIN, and does not need to be replaced.
SOURCE: FACTORY ALARM CAMRY TOYOTA 2002 WENT OFF WHEN i WAS DRIVING
If your remote is attached to the key in the ignition, it could have been bumped setting off the alarm. It is also possible for the lock button to be depressed and lock the doors, if you do not notice this and get out of the car........!
SOURCE: How do I replace the driver side headlight on a
might have to take out the battery, but if you do, dont without a plug that goes into the liter and has a 9 volt battery to keep computer codes. but i dont think you do but you have to have small hands.
SOURCE: replace starter on 2002 toyota camry
Jack up car remove 2 or 3 bolts, undo 3 wires and it comes right out.
[Information] For a 2002 Toyota Camry, the Daytime
Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to
the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test
configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness
when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not
burned out. If one burns out, there is a fair chance that the other would have burned
out at the same time. Replace as necessary.
In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function
Switch on Turn Signals in "DRL" position, headlight switch off
(repeating what the manual says -- it should be obvious that in the
"DRL" position, the headlight switch should be off / do not have the
switch positioned to "High Beam"), and the Parking Brake
"off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box.
there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3).
Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues
could be that the Multi-function Switch is broken or a connection / wire is
broken. [Beyond the scope of this
process.]
My problem was that the test configuration did not have
the engine running and parking brake off - Step 1. Problem solved with much
thought, repetitive tests on the vehicle and going back to the basics -- what
does the Owner's Manual say and where are the applicable fuses and relays
located?
