That error indicates that your fuser is not getting hot enough to fuse the toner to the paper. If you can get to it then make sure all the cable leading to the fuser are hooked up well. If they are and nothing has wiggled loose then the fuser is likely faulty and needs to be replaced.
After extracting the files and getting the error message that you OS is not supported, browse to the Companion Pro LL V2_0_4 folder and open the Companion folder. Double click setup, and only install the Printer and scanner drivers when prompted. The default location that the software is saved to is listed below...
C:\Users\"your user name"\AppData\Local\Temp\Companion Pro LL V2_0_4\Companion
oh its a big problem.fusing temperature error means that either the thermostat or thermister is open in fuser unit. only a Ricoh technician can check it and tell you as it requires a lot of stripping to take fuser unit out and test the thermostat. there is no reset procedure for it mate.
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Sir,
this error usually ocurs when you towner is empty or have completed is age.But as you said error fuser temp this might be that you priner buffer has got damaged while it repaire able bus is expncive so I would rather suggested to buy new one printer and Canon and HP are the best brand in my dictionary so you can try one of them.
