SOURCE: My machine was working perfectly
Pulsing water means the pump is cavitating or losing pressure. One of two situations causes this:
The introduction of air into the system through low water pressure or a leak in the hose.
Try bleeding the air out by holding the trigger on the wand and letting the air out before turning it on.
The seals in the pump can be affected by corrosion and debris. cleaning out the debris with a pump saver can help sometimes. You can buy pump saver at any pro shop like www.arcolawn.com.
I hope it helps.
Joe
SOURCE: Karcher Power Washer -power is
Sounds like the unloader is cruddy with mineral deposits and sticking, if you pry off the silver cap, remove the black cover, use an Allen wrench to remove the two "star" screws (or you can remove the four engine mounts and remove the whole engine), lift out the white plastic part with the brass needle & spring, finally lift out the stainless steel piston or start up the engine (make sure you have the water hooked up and running) and watch out for the piston as it will shoot out ( placed a towel over the piston before starting the engine). Then you can put white lithium grease all over the piston and reassemble
SOURCE: The water is coming out
this thread should help, Tim:
http://forums2.gardenweb.com/forums/load/tools/msg0521035628374.html
