Belkin Basic Wireless Router Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get the wpa2 key - Belkin Basic Wireless Router
Prashant M
Level 3:
  • Master 2,278 Answers
  • Posted on Aug 21, 2010
Prashant M
Master
Level 3:
Answers
2278
Questions
Helped
978541
Points
6246
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
How to connect?
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router.
I need a network security key
Network security key
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Security key does not work
Zyxel 660hn to xp on a compaq 6710b won't accept 13character WPA2 key on sticker on modem
Try resetting the router/modem to factory settings. It is possible the saved WPA2 key is different then the default key so it is stopping you from adding the WPA2 key on the device.
My wep key
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
What is the wpa2 key / //
Wi-Fi Protected Access (WPA) and Wi-Fi Protected Access II (WPA2) are two security protocols and security certification programs developed by the Wi-Fi Alliance to secure wireless computer networks.
You need a WPA or WPA2 key to connect your Game console wireless to the wireless accespoint.
What is my wireless password
The router's password is a Passphrase or the WEP or WPA or WPA2 encryption key.
The Passphrase generates the WEP or WPA or WPA2 encryption key and this is in the router's wireless settings.
To connect to your wireless router, it needs the router's wireless settingsconfigured ie SSID, WPA or WPA2 encryption key and also the wireless cards inall the laptops and or computers needs to be configured with these router'swireless settings. Then the laptops and desktop computers can communicate withyour wireless router.
5helpful
2answers
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
