For what you describe it would appear as if there is a problem with the cockwheels assembly on your Casio watch. Most likely as a result of a severe impact. hard enough to dislodge the retaining plates or break of the bottom of the minute hand spindle.
Hope this helps
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Your hands need to be reset. It is possible that you have dropped your watch or have knocked it on something to make them come loose. You need to take it into a jeweler or a watch repair person to have it fixed because they will need to open the watch up to solve the problem.
There are two reasons for this. First- you distorted minute hands hole and now it is not sitting tightly on pinion. Second- when you pulled off the minutes hand, you lifted cannon pinion. As the result it is loose and swings freely. I do understand you have no knowledge how the watches are build, so, visit your nearest watch repair shop and ask to fix it. Please, do not take it personally - it is just because you can't do that without watchmakers knowledge, so, save your nerves, time and watch. Rate me, plz.
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch). As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly. (Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually. Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops. If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out. Do not forget to rate, please.
