Lexmark Z1480 InkJet Printer Logo
Posted on Aug 14, 2010
My Lexmark wifi printer wont print because it thinks it's already printing something but it's not. Any ideas?
1helpful
Printer connected to a network, prints hours later.
Hi. Try printing from another computer and see if the problem remains. If not, the is probably something wrong with the first computer. If no luck, try updating the printers firmware. Here is a download link
http://support.lexmark.com/index?productCode=LEXMARK_MS510&page=product&locale=EN&userlocale=EN_US#1
Good luck.
5answers
Does not print from my computer
Try to do a test print using the printer utility installed on your computer and also check if the driver is properly installed on your computer and if not make sure that your printer is using the printer driver from your setup CD.
Hope that helps...........
IS LEXMARK WIFI COMPATIBLE
There are Lexmark printer models available in the market that are WiFi compatible. Please visit the Lexmark website for more information about Lexmark's wireless printers. You might find one that will suit your printing needs.
The Lexmark X7170 printer does not support wireless printing. It doesn't have a wireless network adapter to connect to your wireless network.
5helpful
2answers
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
1helpful
Prints garbage
You have a software problem there. You can try and clear the print job in the computer but more than likely its already in the printer memory and is going to print until its finished. I think you're going to have to let it run until its finished then go back and make sure your computer malfunction is fixed before you try it again. I know its frustrating...but it will eventually stop. You might want to re feed the used paper unitl it does. I'd say turn it off and on...but I don't think that will clear the print job..and you've probably already tried that anyway.
Odd behavior when printing
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
2answers
Wireless Connection
I have the same problem and I have exhausted all options that I can think of. Last night I reset the network settings for the printer and started over and at the end, after going through the whole wizard again, it spit out a new network page and looked like the problems were fixed. (was now on channel 11,used to be on 6, also said it was connected to the wireless network when before it said it was not). I got excited thinking it had finally connected, but when I went to print a test page I got the same communication problem error message. I just got off the phone with Lexmark Support and he told me it was most likely printing to the wrong port. When I go to my printers properties page, it is printing to USB001 (Lexmark virtual printer port), and he told me it needs to be on "Lexmark 1400 Series" port. I will try to create a new port tonight and hopefully I have "Lexmark 1400 Series" as an option to choose from.
Jeez this thing is exhausting. I consider myself to be fairly computer savvy and I have wasted 4 nights working on this thing to no avail. How do people who don't know their way around a computer handle wifi printing to the 1420??
Wifi
Follow the instructions in the below URL under the sction "Setting up the printer for wireless printing".
http://www.lexmark.com/publications/pdfs/2007/1400/en.html
5answers
Lexmark 1200 series
Does it power on? How is it connected to your computer? Did you install the drivers for it?
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
