20 Most Recent
Lexmark Z42 InkJet Printer Questions & Answers
Printer prints words on top of each other
Check to make sure that there is nothing preventing the page from being pulled into the printer. Overlapping words is often caused by the paper feed not moving quickly enough, subsequently causing words to overlap and not span the entire page.
If that doesn't work, let me know and we'll troubleshoot further.
Will my old lexmark model
I regret to inform you that the Lexmark Z42 printer is not compatible with Windows Vista. For Windows, this old model is only supported in Windows 2000, Windows NT 4.0, Windows Server 2003(32-bit) and Windows XP(32-bit).
All in one lexmark X73 drivers, Will Z42 driver work?
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
I don't know if another printers drivers will work, give it a try.
Thanks,
Ekse
Paper wont feed thru the printer
hi!! in that kind case my troubleshoot of that is the feed mechanism was defective and try to bring that in your nearest lexmark service center.
My printer will only print test pages ! Non-stop !
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Prinet lexmark z42
If there is less than a year you have the printer, hurry to warranty repair because it seams something's wrong at the power part.
Fact is you can not replace the transformer or other such parts in the printer.
