Re: What temp should the frig and freezer be set at
The freezer should be kept at 0 degrees F and the refrigerator needs to be kept lower than 40 degrees but not colder than 32 degerees (so it doesnt freeze)
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed. This seems to be an issue with Sub-Zero.
