I WOULD DOUBT THE BOARD IS AVAILABLE and you if you have convergence
problems can have it repaired for 1/10th of what it would cost.
Only Two IC's and or one or more resistors fail on this board.
It is easy to actually get the board out of the set.
See attached photos of the board:
It uses two of the STK-392-110 chips ( A pair can be purchased on EBAY
for about 12 dollars!) If one or more of the resistors are bad they are
easy to locate and replace---generic part and each part on this board
has a location number printed next to it.
Less than 20 dollars in parts, about 40 minutes to remove board, replace
parts and put back--all you will need if it works is the JVC remote to
use to adjust convergence.
If this told you something (or the photos helped you) rate this solution as, very helpful as I do this here for free.
Regards, SD TECH
view of board from back removed from set
Dear SIR
Please send me - b418bd3.jpg>
view of board removed froDear SIR
Please send me - cdbf581.jpgfront
view of back side of board--two stk-392-110 chips and in front of them the protection resistors
