WHEN I START MY COMPUTER IT ALWAYS ASK TO PRESS F4 TO BOOT D865GVHZ
VERSION AAC72418-109
Normally this happens if your MB sensor circuitry is not detecting the correct speed of your fan or the correct temp of your system and proc. Try to Load the default settings of your bios and test again. if still having same problem what I suggest is check the 12volts output and 5 volts output of your PSU. To check it you need a Multimeter set to DC volts and put the negative probe to the black wire in a standard PSU plug and the red probe to the yellow cable (for 12v) and for the 5 volts just transfer the red probe to the red cable. If you have the correct voltage output, you have to hot wire your Proc Fan to get DC supply directly from your PSU. Your Proc Fan normally runs using 12volts DC.
Hope this helps.
Problem with PC Desktops
my pc just beeps every 2 to 3 sec no vedio
Posted by
mike russell on Apr 02, 2012
normally this happens if your MB sensor circuitry is not detecting the correct speed of your fan or the correct temp of your system and proc. Try to Load the default settings of your bios and test again. if still having same problem what I suggest is check the 12volts output and 5 volts output of your PSU. To check it you need a Multimeter set to DC volts and put the negative probe to the black wire in a standard PSU plug and the red probe to the yellow cable (for 12v) and for the 5 volts just transfer the red probe to the red cable. If you have the correct voltage output, you have to hot wire your Proc Fan to get DC supply directly from your PSU. Your Proc Fan normally runs using 12volts DC.
Hope this helps.
