Delonghi magnifica, wont turn on!!\r\nwas going fine the other day, now it just wont turn on if i turn it on and off from the wall it starts self diagnosis the goes back to its defult off setting and wont doa anything
Does anyone know what the problem is and what the resolution is? I'm also having the same problem.Does anyone know what the problem is and what the resolution is? I'm also having the same problem.
You can't post conmments that contain an email address.
Ground coffee beans can squirrel their way into hard to reach places in a grinder and cause problems. I think it is clogged with grounds. Remove the beans. Reseat the burr (grinder). Reset the adjustment ring to 3. Lock itin place with the silver handle. Reinstall the hopper and beans. Here is a tutorial on more advanced cleaning and maintenance: You can skip the ad. Delonghi Magnifica Evo ' How to clean and maintain - YouTube
Question moved from 'Advance Computers' to correct category.
This particular machine is mentioned on Fixya 3 or 4 times a week, in fact I answered one yesterday. They have a history of problems. Your issue is likely the control board and would need dealer servicing. Having said that, this page lists most part as 'Obsolete - Discontinued'.
? 2:37 https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
I had this problem. The door didn't snap when I shut it and it would pop open and stop the brewing. It was an easy 5 minute fix.
I removed the drip tray and the black plastic bin where the spent coffee grounds are expelled. With a flashlight I could clearly see 1/4" to 1/2" caked coffee grinds lining the back of the cabinet at its base. This residue kept the bin from seating correctly. Because the bin wasn't all the way back into the cabinet it put pressure on the door and kept it from latching. I cleaned out the buildup with a small spatula and a brush and the door latched perfectly again.
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
