We suddenly have lost sound from our radio. All other functions seem to work i.e. station changing, picture for DVD, volume indicator goes up and down. The Fuse that controls seems to be in good condition. Radio is the REV model. Please help if any ideas on what could be the problem an how to fix.
JustAnswerhttps://www.justanswer.com > chrysler > anxib-chrysle...
Sep 8, 2017 - This sounds like the display board in the radio has failed. But try rebooting the radio first by disconnecting the negative battery cable (in ... 1 answer · Top answer: Hello, my name is ***** ***** I will assist you today. This sounds like the display board ...
YourMechanichttps://www.yourmechanic.com > Questions
Jan 25, 2017 - I have a 2006 Chrysler 300 limited edition, and the screen went black on my rec nav. I can only change preset stations, eject CDs, adjust volume ... 1 answer · 36 votes: Hello. The issue you are having with your radio is a common problem with Chr
Was it just replaced? No tuning is the antenna wire wasn't plugged in. It would get stations manually, but with static. Not lock by itself. No sound could be a bad replacement radio or an amp. Check the amp fuse first.
Did you find the problem with your radio Terry? I have a 2005 X type and the radio has just suddenly started doing exactly the same thing - cant change radio station or use steering controls, only the volume knob works.
2008 Altima radio-the sound just quit working. Everything else seems to be OK. I can change the radio stations, but no sound. Is there a fuse that could be bad?
I have seen this before, You should pull the radio out and get the serial number off of the back. Call your dealer and get the radio code. Disconnect and reconnect your battery and input code given by dealer. Usually this occurs when you change or let the battery rundown, it is an antitheft feature. Most of the time you would lose all functionality but in your case there may have been some kind a electrical surge that tripped part off your radio functionality. Please let me know if this works for you.
