Re: Lost stickies notes. New note list appears under...
Sticky notes can be saved. But once you close the sticky notes without saving it, you cannot get the details typed on it back. One thing special with sticky notes is, you will get it back even if you shut down the system provided you should not have closed the sticky notes.
It's probably having problems loading the page.
Click on Menu in the upper right (looks like three stacked lines)
Click on Settings
Look for "Show Home" under Appearance.
Click on "Change" to change your homepage to whatever you want.
Depending on the typewriter model, most all have release points located on either end of the roller bar. Locate these, push forward or backward, release roller bar and lift the bar out. This would be the preferred solution, as it would make removing the sticky note far easier. These release points will look like small levers and should have directional arrows visible to indicate which directions they should be pushed to release the bar. If you cannot remove the roller bar, I suggest standing over the typewriter and use a pair of tweezers to remove the sticky note. It may take some patience, and may tear, but eventually it should be able to be removed,even if it is bit by bit. Also, with each portion removed, turn the roller bar to make the remaining part of the note more visible. Good luck.
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text s largest to smallest and Full screen option
Open the Properties / Preferences window for the printer.
For Windows 7
Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/ Me/98 (if applicable)
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click on the Main tab.
Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
Note: The pigment black ink will only be used when printing on plain paper.
De-Select the box for 'Grayscale Printing'.
Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
For Windows Vista
The sound is normal for this printer however; you can reduce the sound by:
For Windows Vista
Note: This setting must be set from the Printers Folder. If the printer Properties / Preferences are accessed from an application, the setting will be unavailable (grayed out).
Click the 'Maintenance' tab, and click 'Quiet Mode'.
NOTE: Available maintenance options vary depending on model.
Select the desired setting:
Note: When using the option for 'Use within a specified time,' if 'Start time' and 'End time' are the same, Quiet Mode will not be applied.
Note: Quiet Mode may not function when 'Use quiet mode within specified time' is selected and a test print is printed directly from the printer via the Resume/Cancel button.
Confirm the printer is turned on, then click 'Send.'
When the confirmation message is indicated, click 'OK'. The selected settings will be applied.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
How To Transfer images To Your Windows XP/VISTA
PC
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;}
To transfer images
from your camera to your Windows XP PC, follow these steps:
Connect your
camera to your PC using the USB cable.
Turn your camera
on, and then select the 'Computer' option on your camera.
After you have
selected the computer option, a pop-up appears on your PC informing you that
Windows has found new hardware. Close the pop-up.
Double click the
'My Computer' icon located on your desktop. The My Computer window
appears.
Double click the
'Removable Disk' icon in the My Computer window. The Removable Disk window
appears.
Note: The drive letter associated with the
removable disk may be different depending on your system.
Double click the
folder names DCIM in the Removable Disk window.
Find the folder
named 101SSCAM. The images taken with your camera are in the folder.
Note: Each folder in your camera contains up to 99
images. Once this limit is reached in an existing folder, your camera creates a
new folder. The folders are labeled successively: 102SSCAM, 103SSCAM,
etc.
To copy the
entire folder to your PC, right click the 101SSCAM folder. A menu
appears.
Highlight 'Send
To' in the middle of the menu. A sub menu appears.
Select 'My
Documents'.
Windows copies
the folder into 'My Documents'. Depending on how many photos are int he folder,
copying may take a few minutes.
Double click the
101SSCAM folder in My Documents to access and view the pictures taken with your
camera.
How To Transfer images to Your Mac
PC
To Transfer images
from your camera to your Mac, follow these steps:
Turn on your Mac,
and then connect your camera to your Mac using the USB cable.
Turn your camera
on, and then select the Computer option on your camera's screen.
An icon appears
on your Mac desktop labeled Untitled.
Shortly after, a
pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
After downloading
is complete, another pop-up appears containing the pictures taken with your
camera.
Access the printing preferences by opening the printer Properties/ Preferences.
For Windows Vista
Click
Click
For Windows 2000/Me/98
Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
Print using pigment black ink only (Windows)
Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
For Windows Vista
Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
Custom Paper Wizard
PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard.
Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
Click Next.
In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
Click OK.
To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
Launch PrintMaster® 17.
Click Help on the menu bar and select Help Center.
Click the View or Print Tutorial icon (light bulb).
Under Choose a Category, click Program Tutorials.
Under Choose a Topic, click Using the Custom Paper Wizard
