Have put in 2 different sets of new blk. ink cartridges, cleaned print heads, says they are not clogged, have deep cleaned print heads, still no text printed in black but other colors work.
For Windows 7 For Windows XP Home Edition The printer will now only use the pigment black ink tank.
For Windows Vista
For Windows XP Professional Edition
For Windows 2000/ Me/98 (if applicable)
Note: The pigment black ink will only be used when printing on plain paper.
Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
