you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
Are the new cartridges original parts or copies? Some machines are very fussy. If the parts are genuine try removing and reinstalling them a few times and see if this helps. (This may also work with copies!)
First thing is are you putting the key in correctly - worth checking. With that small writing it can take me 3 or 4 attempts
if not one of the viruses you have been hit with has been used to steal your key. if so you need to contact Microsoft
Doesnt sound like you Used Genuine Cartirdges? Did you use Epson Genuine Cartridges?ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!! That sounds like your problem. In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. . IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR. This is the only advice I can give you. The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.: http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues. If you find this helpful, pls rate me.
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
