Troubleshooting & Support
Hot Topics:
- won print
- cleaning ink...
- lights flashing
- print test...
- reset
- black
- black print
- clean print...
- paper feed
- driver
- RED LIGHTS...
- blue
- windows 64 bit...
- multi page...
- print head
- head alignment
- won print ink...
- service utility...
- ink pad
- load eject...
- windows 7...
- ink light...
- head cleaning
- epson stylus...
- drivers
- 10
- paper feed jam
- printing
- instal driver
- View All »
Problems & Solutions
Unit makes every noise and motion as if printing,...
First thing is if you haven't printed for while the ink may have dried in the print head. Run it through a few (lots) of print cycles...
head cleaning not working
Doesnt sound like you Used Genuine Cartirdges? Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges....
Epson Stylus Color 740.All indicators flashing
Sounds like the printer may be jammed. When it goes through it's initialization process, it checks ink cartridge movement, and scanner...
the black cartridge is leaking, what should i do?
Hi, I'd stop using the printer, and purchase a genuine epson black cartridge to see if it stops leaking. If so, and you are happy to buy...
can i conect to windows xp
Yes you can If you do not have the disk you must download the software from Internet, follow instructions below, Click here I...
Problem with colour printing. Orange and green
Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't...
no power at all
Try looking inside for fuse. You will have to fully remove top and bottom. If fuse is good, then the power supply is bad.
Epson 740 displays 3 red flashing lights on power
See your other ticket... For those who are visiting and seeing this... it's a service required indicator.
Epson 740 printer seems totally dead, all lights...
Already solved.
Seemingly full Epson 740 ink cartridges don't...
Problem is solved.
Eson 740 will no longer print black ink
Thank you Scott Ellin for your tip on connecting the Epson printer to another computer, that helped. I connected it to my OS 9 Mac and...
I need to replace the color ink in my Epson stylus...
To force a Cartridge change press and hold down the Paper feed (load eject) button for over 5 seconds and the cartridges will move into a...
Epson Stylus color 740
I would purchase a replacement printer as you can get a better one for 40$. Time is money and not worth wasting any more time and money on...
Need to change dried old ink cartridge before it...
While the printer is on, press and hold the paper feed button. The ink cartridges move into the replacement position. Also useful to make...
Failure to print
inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero...
Unsolved Problems
epsom stylus 740
The ink cartridges are old and blocked as the printer hasn't been used for 2years. Cleaning the heads several...
I'm looking for Epson integrated intaller
I'm looking for Epson integrated intaller version 2.35 for Epson stylus color 740!
I recently installed the Epson
I recently installed the Epson Stylus Color 740 printer. But it won't print.The 'no paper' indicator is on...
want print its say have
want print its say have ot enable buts is already enable want print email nothing from computer its say its been sent to...
ink cartridges full but nothing
ink cartridges full but nothing appears when printing for stylus 740. Ran a printer head test. Was working earlier
After storing my epson stylus
After storing my epson stylus 740 for about 4 years I hooked it up today and everything works except no ink on the...
I have a printer
I have a printer stylus color 740 . when printing the color print is O.K. but the black misses one line each time...
hi there, my Epson stylus
hi there, my Epson stylus 740 is making loud screaching, then clicking noises when I turn it on. Then it doesn't print...
Upload a manual for Epson Stylus Color 740 InkJet Printer
Specifications
TopKey Features
Full Product Name:Epson Stylus Color 740 InkJet Printer
Platform:PC, Mac
Type:Personal
Technology (Detailed):Inkjet
Max Resolution (Color):1440 x 720 dpi
Black Print Speed:6 ppm
Output Type:Color Printer
Max Resolution (BW):1440 x 720 dpi
Color Print Speed:5 ppm
Technical Features
Form Factor:Desktop
Language Simulation:EPSON ESC/P 2
Media
Media Type:Transparencies
Media Type:Plain Paper
Max Media Size:Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity:100 Sheets
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
14,420
14,420 people have viewed this product
- 155 people asked about this product.
- 65 people found solutions for this product.
- 4 people have added this product.
C46 Squeeling...
Epson Stylus...
How to fix if...
