Right click
on the my computer icon and select Manage. Click on storage to expand
the selections and select Disk Management by clicking on it. Do you see
a CD-ROM 0 DVD when scrolling to the bottom? If not your drive cable is
not connected, defective or the DVD drive needs to be replaced. Do you see a
drive letter assigned to the drive? If you do not right click on Change
Drive Letter And Paths... and click
on Add. Select a drive letter and click on OK. Can you
see your drive in my computer? If not click on Change Drive Letter And
Paths... and click on Remove
and OK to confirm. Right click on Change Drive Letter And Paths... and click on Add. Select a new but
different drive letter from what was previously assigned and click on OK.
If this works you have a conflicting assigned drive. If none of the above works
unfortunately the drive is defective.
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone.
Hope this helps
