I have a problem with my XeroxWorkCentre pe 120. The problem consist in the following simtomes:
-the printer,scaner, fax is working fine until one moment,i guess that moment is the time that the printer enters in standby, when that happens, i need to restart the printer, sometimes reinstal the drivers on the PC, this is verry annoying, everytime i need to print something i have to reset the printer,that takes like 2-3 minutes, and after that reinstal the printer that takes like 2 minutes, and after that finaly to print 1 or 2 pages...(that takes 5 minutes, im better of finding a friend with a printer that work fine)
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray.
Cause:
Extended tray is not set up properly for envelopes.
Solution:
Fixed! Did not fix.
Enter tools "Login" 1,1,1,1,1
Touch buttons with the following names in that order:
System Settings
System Settings
Common Settings
Other Settings
Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking"
Close out tools.
SOURCE: Xerox WorkCentre XD100 driver
That very much sounds like a driver problem.
One thing you may try first is when you get to the download page for the drivers.Select ALL on the driver page. Normally you get one selection to show up when you just click on the driver page. When you click ALL then Go and you will see more options.
There is not a Vista driver for that product if that is your operating system.
Maybe just delete the printer and re install. Something is wrong with your driver, corrupted or just not functioning correctly.
I do not have my laptop with me right now, I left it at the office with my other documentation on it.
I will look up more in the morning for you.
But this very much strikes me as a corrupt driver problem.
SOURCE: 2 sided printing problem
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
SOURCE: Docuprint c525a only prints first 2 pages of document
Change the paper size in the program you are printing from and delete all paper size changes later than the beginning of the document.
Change it on your default printer and anywhere else you can.
Usually it is asking for different size of paper and will display this on the lcd
SOURCE: Xerox Phaser 8560DP shows annoying 'print completion' message
Someone installed the "Printing Scout" on this computer. You may need to uninstall or check all the settings in the printer driver. I'm not really familiar with Macs but I know the 8560 inside out, upside down, and backwards.
