The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
This is known issue of ccd imager chip failure in Sony DSC-T33 camera and ccd imager chip will be replaced to get correct live view to take pictures.
Required ccd imager chip is available with Part Store for $52
Let me know if you have additional question.
Thanks.
put your camera mode in t "P" setting then go to menu & you should see color or pictue options to switch the color back to color....i have a cybershot dsc-w55 idk what u have but try that .... GOOD LUCK !
I had the same problem with my camera. I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures. Go to Menu and scroll over to Mode, then select Normal.
camera ccd is / has failed - also possible , lens
iris is stuck closed ( on monitor , can see very
faint snow noise against black background - check
if iris opens , by shining penlight into lens );
