I can help you reassemble your tension control for your Singer Sewing.
I know that you can get exploded parts charts and service manuals for Singer Consumer and Industrial products from sites like this.
The exploded parts diagrams look something like this: (for this 261U41 model)
I suspect this is the type of document you are looking for.
To provide more help sourcing the information you are looking for, I require more specific model information on your sewing machine:
I hope that helps.
I hope this user manual may be helpful.
Kind Regards.
This model may be helpful. Trying to find model 456.
Singer Genie 353 – 354 Panel removal guide
And this is model 457 Schematics.
Hope this helps.
Waiting your comments.
As I see in your last comment, your problem is solved. If it is solved with my solution, would you please accept and rate my solution to be able to close the case.
Thank you.
Thank you.
Hi
The top and bottom tensions of your Brother sewing machine must be in balance to make good-quality stitches. If the tension is not equal, the stitches will appear loopy on one side of the fabric, or the fabric will bunch up as you sew. A numbered tension dial usually is located on the top of the machine, which controls the tension of the upper thread. The bobbin case usually has a tiny screw which can be turned slightly to adjust the tension of the bottom thread. The bobbin thread rarely has to be adjusted. A balanced tension normally can be achieved by adjusting the upper thread tension dial.
Please check the bellow links …
http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf
http://www.westsidesewing.com/wss/tips/art_pt02.pdf
http://sew4home.com/tips-resources/sewing-tips-tricks/319-sewing-machine-tension-control
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
i have taken the tension control completely apart on my singer 456. i cannot get the parts back in the correct order. i have a spring,wires,plates . i need to see a diagram of the assemebly order of parts. i have seen and read all the articles on top/bottom tensions. i have a big tension problem. someone out there must know how to do a "put humpty dumpty back together again.
i have completely taken the tension control apart from my singer 456, i now have a bowl full of parts, does anyone know how to re-assemble the tension and all of its parts? the manuals that singer has does not go into this depth.i need drawings of the parts and how they go on the shaft.i cannot sew without this fixed as you know.
mahalo! this should do it.clear,clean drawings !
you have taken the "tension" out of my life!
