Visioneer OneTouch 5800 Flatbed Scanner Logo
A
Anonymous Posted on Jun 25, 2010
I can't find my driver cd that came with the scanner is there the whole file some where on the net the one from visioneer is useless it does not detect that the scanner is connecyted to the Computer.
Duane Wong
Level 3:
  • Master 6,826 Answers
  • Posted on Jul 09, 2010
Duane Wong
Master
Level 3:
Answers
6826
Questions
6
Helped
2862305
Points
20234
Unfortunately, if the manufacturer has a bad driver, then the one on the cd is probably bad, too.
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
2answers
I had a new install of windows xp (with service pack 3)on my computer and am now trying to install my visioneer one touch 8700 scanner. Is there a problem with the driver and the xp service pack 2? How can...
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
2answers
Have the drivers been updated for Visioneer Onetouch 8920 scanner
Below is a link to the list  of the only scanners that VISIONEER has written a Vista driver for(and not likly to write any more for former scaners.)  Your model in not on that list. Unless, for some reason , they decide to write a Vista driver,you will never bve ableo to use that scanner with the Vista  OS. No one else will ever write one either.     Please don't rate me badly for telling the whole truth even thought you may not like it.  http://support.visioneer.com/products/tools/os/vista.asp
The below link is where I took the followign from:
http://support.visioneer.com/UK/products/tools/OS/
As Microsoft continues to release new versions of it's Windows Operating System, the requirements for peripherals and software change. Visioneer scanners are designed to leverage the tools and features included with the operating systems that are current when products are released. When feasible, we develop scanner drivers for new versions of Windows. On the day Windows XP was released, Visioneer had more scanners qualified to wear the Designed for Windows XP logo than any other scanner maker. In spite of our best efforts, major changes in the underlying architecture of Windows XP make it impossible to write new drivers for many of our older model scanners.   Visioneer posts the last release of drivers on each Product's Homepage and provides online support for older products. Scanners designed to work with older versions of Windows may not function properly after upgrading your computer's operating system.   We offer an industry leading upgrade program, giving a 25% discount from our online scanner store for customers that return their old unit to ensure proper disposal as part of our environmental recycling program. For details visit Visioneer's Trade Up Offer.
Vista driver for visioneer 7100
I just downloaded the XP driver for this scanner from the Visioneer web site. It came with just the driver, as I recall, or you could order the replacement CD for just a shipping charge of under ten bucks. They may have one or two other programs that they supply for download, and they had links to third party vendors who supply the other software on the CD.
I believe that they had a Vista driver for it as well.
I also downloaded the file--and I believe that it was larger in size than the Visioneer download--from driverscollection.com. I have not yet installed that download to see what the difference might be.
3helpful
2answers
Lost installation cd for visioneer 7600 scanner usb one touch
Hi! I have the correct driver for the Visioner 5300 / 7600 that will work with Windows XP and Vista. I can provide you a copy with complete instructions for installation. Please e-mail me at: [email protected]. Subj: 7600 driver.
Scanner
After downloading the visioneer 9420 driver file (found on the visioneer site, but before installing it, remove your old 8100 driver, then install the 9420 driver by running the .exe file you downloaded from visioneer. Then, use Device Manager, go to -update device drivers and in the listing you should see the 8100 listed. Double click on it, click on -update, go to -browse my computer for driver software, then go to -let me pick from a list, then you should see the 8100 scanner appear, click on it, click on next, and then it will install the 9420 driver. My 8100 is working great on a vista system. Don't get rid of that scanner! It works!
My Visioneer P7300 Scanner seems incompatibile with WIN XP
Hi Bob,
It's quite possible. Does the scanner connect to the computer via a USB or parallel (old style printer) port?
If the answer is USB, then I believe you might find what you need HERE.
My only reservation is the "P" in the model name you gave. I didn't find any Visioneer scanners w/ a "P" in the model name. However, this one lists drivers going all the way back to Windows 98SE. So, this may very well be the ticket.
Take a look at the picture of the scanner you see at the link I gave you. If it looks right, go ahead and download the manual and take a look at that. If, after viewing the manual, you're convinced it is for your scanner, then go ahead and download the drivers for it and install them on your XP system.
As always, make sure you create a System Restore point b4 making changes to your system like installing or uninstalling software or drivers.
Please, let us know if this worked for you. If you have any more questions at all on this topic, just hold of on rating the experts' contributions so the problem will remain open. (Once you assign ratings, the problem will be automatically closed and we won't be able to continue assisting you.) We will continue to work w/ you until you're all set and no longer need our assistance.
Thank you,
BJ @:)
I'm having problems with my scanner........
try installing this http://support.visioneer.com/drivers/4400/ENU/4400.303110.EN.exe even thought it is xp driver, I think it should work better than original Vista driver.
Good Luck
2answers
Visioneer One Touch 8100 Scanner
You need up-to-date driver software to detect it. Check your driver software availability.
Top Visioneer Office Equipment & Supplies Experts
littlewheel
Grand Canyon Tech
Grand Canyon Tech
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
