Sentry Fireproof Safe Logo
Posted on Apr 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open my safe with the code - Sentry Fireproof Safe
A1 Locksmith Burlingame
Level 2:
Scholar:
  • Sentry Expert 170 Answers
  • Posted on Sep 18, 2010
Sentry Expert
Level 2:
Scholar:
Answers
170
Questions
0
Helped
252786
Points
258
How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 02, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2914
Points
I want to chang my code but i forgot and lost the book instructions
1helpful
How do I reset a code for a small safe box
Instructions for an Electronic Digital Safe
  1. Enter your code on the keypad located on the front of the safe. ...
  2. Turn the handle to the right within five seconds of correctly entering the code. ...
  3. Open the safe with a key. ...
  4. Enter your code to open the safe.
  5. Place the electronic digital safe into code reset mode. ...
  6. Enter your new code on the keypad and press "#" to finish.
https://www.hunker.com/13419338/instructions-for-an-electronic-digital-safe
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • 0helpful
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Says code error
    How To: Open A Locked Sentry Safe If You Forgot ...
    ? 5:21
    https://www.youtube.com/watch?v=Mr8QrvVAtuI
    Jul 15, 2014 - Uploaded by TipsNNTricks
    I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
    ' Sentry® Safe ' Lost Your Combination
    https://www.sentrysafe.com/.../Lost_Your_Combination
    Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
    opening a electronic safe forgotten the lock code ready to ...
    www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
    InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
    How to Crack a Safe (with Pictures) - wikiHow
    Have key and code...safe will not open
    Sentry Safe not unlocking - YouTube
    ? 0:36
    https://www.youtube.com/watch?v=4mbtSUAoS6w
    May 8, 2013 - Uploaded by 1diazsantana1
    When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
    Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
    idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
    May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
    My safe, a Cathedral EA15 Will not lock. Any suggestions people?
    Instructions
    1. 1
      Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
    2. 2
      Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
    Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
    1. 1
    2. 2
      Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
    3. 3
      Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
    1. 1
      Use your code to open the electronic digital safe's door.
    2. 2
      Locate and remove the battery cover on the inside of the door.
    3. 3
      Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
    4. 4
      Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
    19helpful
    2answers
    I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
    I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
    What can i do
    5helpful
    2answers
    I cannot open safe with the usual code.Safeguard electronic digit
    To open a Safe International Digital Electronic Safe
    User override key to open safe
    Then:
    a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
    b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
    c. To change code repeat step a.
    Test your new code before closing safe.
    9helpful
    2answers
    Sentry Safe (DSW3607 Model) Won't Open
    I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
    Top Sentry Home Security Experts
    Grand Canyon Tech
    Grand Canyon Tech
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
