Hi, I've read your "Post" I will try to assist you in solving the problem. "First you want to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics . 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit...) 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. *Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "To finish, "Restart "Computer.”
Hi, "I almost forgot to say, thanks for using Fix'Ya," and if you get the chance let me know how things worked out for you.
Open Screen Resolution by clicking the Start button, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
Choose one of the following:
Smaller - 100% (default). This keeps text and other items at normal size.
Medium - 125%. This sets text and other items to 125% of normal size.
Larger - 150%. This sets text and
other items to 150% of normal size. This option appears only if your
monitor supports a resolution of at least 1200 x 900 pixels.
Click Apply.
To see the change, close all of your programs and then log off of Windows. This change will take effect the next time you log on.
